Find solutions to your computer repair questions.
21244 Questions View all
Ground loop - is that the problem and how to fix it
I have what I suspect to be ground loop. The 3.5mm cable between the line in on my PC and the line out on my monitor is producing a strange buzzing noise. I've tried removing the ground connection between the two, but it didn't help. What I'm really looking for is verification that the problem is really ground loop.
Recording of sound:
https://drive.google.com/file/d/0BxmOW-d...
Supposed solution:
https://www.amazon.com/gp/aw/d/B019393MV...
Score 3
1 Comment:
Anybody got any ideas?
by
Add a comment
1 Answer
hello George A. did u fix these buzzing noises ? was it ground loop ? did that mpow ground isolator solve that ? im asking because i have same problem right now
1 Comment:
No, I didn't buy the ground loop isolator but if you have the problem you should try that. I didnt buy it because I found another solution: to not use a 3.5mm connection.
by
Add a comment
Add your answer
George A. will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 3
All Time: 192
