Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2693 Questions View all
Touch not work fine after Glass only Replacement.
Hi, i fix any screens with Glass only Replacement. But when i replace the Polarizer than works first fine but when glass with oca press than i musst be very hard press on screen that touch work. Please help me to fix that, any sorry for my bad english :-|
Add a comment
1 Answer
Chosen Solution
Have you split it again to see if it works fine with just the polariser? If so, you probably have a bad batch of OCA. Get the green package ROHS stuff, that is the best quality OCA from memory
Score 6
2 Comments:
Hi, yes its works fine agian when i remove the new glass. i have buy a glass with frame and oca installed. you belive i have buy trash ? :/
by
Whenever we had touch sensitivity problems with screens, it was a problem with either slightly thicker glass or OCA. We would apply it to the glass ourselves, so we knew we were using good quality OCA.
by
Add a comment
Add your answer
Christian Bodden will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 79
