The Nintendo 3DS XL 2015, marketed as the New Nintendo 3DS XL, was released October 11, 2014 in Japan and February 13, 2015 in North America.
305 Questions View all
Can you fix lose hinges?
my hinges are lose. and i'm not sure if i can fix it myself or where i should send it to get fixed
Score 1
1 Comment
You could try getting a replacement hinge and installing it, but that's pretty hard if you have never done a repair on a 3ds yet. If it's still playable just deal with it (my dual ips 3ds wobbles like crazy!) or if you can't stand it send it to nintendo
by
Add a comment
1 Answer
Chosen Solution
@snookiex628,beth, You are not the only one with this loose hinge issue, if still under warranty consider using the warranty for repair/replacement/refund. If not under warranty check the links below for a pretty much low/no cost fix and other info. Other wise you may end up having to replace the upper and lower case. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=lj0C4yyI...
https://www.youtube.com/watch?v=e9Zd1CEv...
http://en-americas-support.nintendo.com/...
Score 4
Add a comment
Add your answer
beth snook will be eternally grateful.
Past 24 Hours: 12
Past 7 Days: 76
Past 30 Days: 306
All Time: 16,101
