The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3609 Questions View all
iPhone 5S dead after U2 ic replacement.
I have an iPhone 5s that battery was draining very fast, this happened after using cheap iPhone chargers. I decided to replace the U2 ic, after job done, phone started, booted to IOS and worked fine. I tried to charge this and when I put cable on the phone the screen got black and phone went completely dead. I replace the U2 chip again and no sigh of life. Can someone help me, why is this happened? Why is this worked only for some minutes? I burn any resistor? What parts need to test to find the problem? Thank you!
Add a comment
Chosen Solution
Did you actually check battery health using 3utools or coconut battery?
Score 1
Comments:
battery is fine
by
Add a comment
Most Helpful Answer
Try replacing the Q2 IC (4 PIN IC), right above it. You can harvest a good one from an old board, if you have one.
Score 2
Comments:
Ι don't have an old motherboard, I will order a new IC and I will come back with the result.
by
Add a comment
Add your answer
johnfl21 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 50
All Time: 809
