The M.2 256GB SSD in this MBA W/Red Sensors Won't Boot or Mount
Mid-2012 Macbook Air 11.6" A1406 256GB M.2...
I removed the SSD from an unknown-condition MBA 11.6", Mid-2012. It boots to a question mark, so I pulled the SSD and it has pale-red moisture sensors. I assume it's gotten wet. Would liquid kill this SSD so that it wouldn't even show up at all in a drive enclosure plugged into another Mac?
I plugged it in, unplugged, then loaded Disk Utility wherein there was no SSD to see. One odd thing is how long Disk Utility took to load. So maybe it sees _something_, but can't load it?
I also tried Drive Genius 4: NADA!
I removed it from the enclosure, then cleaned it using 99.9% Tech Grade Isopropyl Alcohol. Dried it then repeated the exercise, again, NADA.
I assume this drive is dead?
Anything else to do other than add it to my Xmas tree?
Thanks!
JoeL
Atlanta
Did you put it in an OWC Envoy? The is a red dot on the sticks that is not an LSI.
by mayer
Sounds like a dead SSD. I had the same symptoms with an SSD from a water damaged Macbook Pro. It had corrosion too, changed the affected parts, still no work.
by Alex
