Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Questions View all
iPhone 6s plus Screen Replacement no loudspeaker or volume controls.
One of the flex cables looks like it was bent on my replacement screen i ordered elsewhere just curious if that would cause no loudspeaker or volume controls. The vibration motor is also weak it just makes a clicking noise with little vibration. Just making sure there is nothing else i could do before i replace the screen. Thanks
3 Comments
The vibration motor feels significantly different when you compare 6 to 6s. It's probably normal but it's sometimes different when you compare a 6s to another 6s it might feel different but I guess that's how it is.
Edited to fix comment.
You did try replugging the battery and turning the phone off and on and see if it still happens right?
Loud speaker is greyed out during calls right?
by
Hey @benjamen50
I think that fact is the same on all phones. As I type on my Nexus 6 right now, the vibration is rather loud. 30 seconds ago it was silent. Just depends on what mood it's in ;). The vibration has changed 5 times in the last few minutes. It can't make up it's mind.
by
I see then it's just a consistency issue. In my experience the iPhone 4s overall have the same vibration feeling.
by
Add a comment
Chosen Solution
That is weird. Usually these things aren't synonymous. However it is possible that if you were having trouble putting the cables off and on, especially the battery connector, which I'm hoping you disconnected during the repair. The 6S 6S+ and likely the same for 7 series. Don't have bleeding capacitors, so rapidly putting the connectors on and off could damage some things. It's apparently the magic number of 12 seconds you would want to wait. Also, you may want to check your lightning dock connector. That would affect the loudspeaker and vibrator motor. As for the volume cables..would have to be considered during the first condition
Score 5
3 Comments:
Thanks iMedic. I appreciate you joining my team! You know the terms, spread the word!
by
Yep. Really glad to be there!
by
I just updated the page.
I'll appreciate it if you write a short bio kinda thing like on master techs. Put it here so I can update our page. Thanks!
by
Add a comment
Woops while taking out the battery connector i had popped the loudspeaker connector off and that screwed up everything. Taptic engine now rattles but that was a cheap fix for my customer. Thanks
Score 1
Add a comment
Add your answer
Jertoc will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 200
