After replacing MacBook mid 2012 hard drive cable still doesn't read
After replacing macbook mid 2012 hard drive cable still doesn't read..... Original cable is 821-1480-A MFC:2812
New cable 821-1480-A MFC:2913
I have found that a faulty cable will mess up the hard drive about 50% of the time. Hook the drive up to an external SATA to USB adapter and see if you can recover it using Disk Utility.
Thanks, have to order another 1 of those too...
Probably a faulty cable if you have tried with a known working hard drive. Check for liquid damage around the hard drive cable connector and burnt inductors in this area. Check bottom of board for liquid damage if you try it with a definitely working cable and drive. There is a chip to the right of the RAM slot on the bottom of the board which is responsible for dealing with the SATA signals.
The chances of this being anything other than the cable or the drive are 0.0000001% on this board, it's not like the newer Retina boards where this is likely to be a board issue. I personally think your original cable is working intermittently, and the new cable is completely bad.
Yeah & it was accidently thrown away
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 247
2 Comments
Hard Drive making any unusual noise? If you have replaced the Hard Drive Cable then theres a chance that its the Hard Drive. Or worse case being the Logic Board.
by Daniel Mason
No usual noise when powering on. Tried different hard drive, still doesn't read. Original cable reads hard drive every couple days for about 2 hour.
by Fett
