A mainstream series of desktop computer sold by Hewlett-Packard between 2011 and 2013.
Desktop won't connect to internet but all other devices in house will
In the house these other devices will connect: iPad, 3 iPhones, mac, chromebook. I have tried disconnecting the modem and router several times. What am I missing?
Add a comment
Is this a wireless capable computer?
Are you using an external Network Interface Card (NIC). Have you tried replacing this?
Have you hard wired it in with an ethernet cable?
Can you ping other devices on the network?
- in cmd type: ping 192.168.X.X (this will be the address for a different device)
Was the device connecting to the internet before?
1 Comment:
Not sure of all the answers to your questions. Yes device was connecting before. Yes it is hard wired in with Ethernet cable.
by
Add a comment
There are a few ways to check the network connection on a PC.
1. Open network and sharing center by right clicking on the network icon on the task bar next to time and date. Check to see if the computer is connected to the internet, you can run the troubleshooter which can fix some problems.
2. Ping the local network adapter by going to command prompt and enter "Ping 127.0.0.1, you should get a response even if not connected to internet, this shows the network adapter is functioning correctly
Reply from 127.0.0.1: bytes=32 time<1ms TTL=128
If you get a time out then the problem is the network adapter.
3. Ping a company like Google, enter on command prompt "ping google.com" and you should get similar responses as in step 2, if you get a time out try next step
4. Enter on command prompt "TRACERT google.com" this takes a while but you can watch the route taken by the command as it goes from server to server until it reaches the target. If it times out, the last connection is good but the next hop timed out. Good command to see if you are getting through the ISP.
5. If you have trouble with steps 2 through 4, check the network adapter where the Ethernet cable connects, most times there are little activity lights that show that you are connected.
Other things that can cause problems with connecting are bad Ethernet cable, bad port on modem, corrupted driver for network adapter, defective key on keyboard and other items specific to your system.
Add a comment
Add your answer
khhook will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 19
All Time: 6,175
