Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 Questions View all
loose connection prevents charging on MacBook Pro 15" 2008
Recent problem: the connection is loose to the magsafe power port, it's difficult to get it to charge unless I push and wiggle it till it seems seated, it stays for a few secs, but then releases itself and the connection is not good enough for recharge. I've managed to get it to stay after several attempts, but the problem will only get worse so want to get it sorted before it won't charge at all. Incidentally the magnetic plug is very hot too. Can I replace the magsafe power port easily?
1 Comment
Thanks very much for such a clear answer. Whether I am capable of working on it I'm not sure, but that's my problem, at least it looks as though there is a way of replacing it. Thanks once again.
by
Add a comment
1 Answer
Most Helpful Answer
This should help.
MacBook Pro 15" Unibody Late 2008 and Early 2009 DC-In Board Replacement
Score 1
Add a comment
Add your answer
lizzie will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 381
