The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
730 Questions View all
Device stuck in a boot loop, and I need the pictures off of it
Hello, thanks to those who can help me. My mothers iPad has a cracked screen, is stuck in a boot loop, and I need to get the pictures off of it. From what I remember the screen still works and is usable, it just has meaningful pictures on it. Is there anyway to get them off/
shift key is broken so cant put question mark lol
If nothing works I can go into taking the sd or whatever storage it uses and see if that will work
Add a comment
1 Answer
Most Helpful Answer
My personal recommendation is to take it to an Apple Store to see if they can fix it. Since no iDevice ever has had an SD card slot, you cannot remove the storage. You would have to do a factory reset through iTunes to get it to work. Unless, the device is connected to iCloud, in which case you can view all of the photos on www.icloud.com. Also, the device should automatically back itself up. Hope that helps! Also, sorry about your shift key!
Score 3
2 Comments:
My nearest apple store is pretty far away... I connected to the icloud site but it says I need iOS 8 or higher to use it. If I download it, will it still have her older items [if she backed them up anyway]
by
It will, but you need to get into iOS to update without a reset. Like I said, an Apple Store is your best option. Sorry I couldn't help.
by
Add a comment
Add your answer
Peter Scollard will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 989
