iMac - Vertical bars - LCD or GPU?
I've got an early 2008 21.5" iMac that has developed vertical bars on the display, as below. Before blindly ordering parts, I'm trying to figure out if the culprit is more likely to be the LCD panel or the video card.
As you can see, the bars are pretty wide, and they don't seem to resemble the typical "vertical lines" issues you see on a lot of iMacs. They seem to manifest as lighter in color compared to the correct color in the surrounding areas.
btw, I already tried the well-known trick of "baking" the video card to re-flow the solder joints, to no avail. I would try testing it with an external monitor, but I don't have access to a Mini-DVI adapter.
Any advice/opinions will be much appreciated!
