Repair Guides for Sony Laptops
415 Questions View all
How to replace FPC Connector on a vpcz21l9e motherboard
Dear Ifixit or others,
I was trying to lock the fpc cable (for lif/zif ssd) to the fpc connector. But I accidentaly broke the pins in the connector. See attachments. I ordered a fpc connector(see last picture) but I don't if this is the right one.
Update (04/22/2017)
On the left it says 40 and on the right 1A. Does anyone know what type of connector this is and where to get it?
1 Comment
Welcome to the forum.
Anyway, the easiest way to tell if it's the right one is to count the pins and measure the size. If you have a number for the parts and they match, that's a pretty good indication too.
by
Add a comment
Chosen Solution
Actually, there is a huge variety of ZIF connectors and the differences are subtle but important. Ideally, if the original one has a visible brand name, then start your research there. These connectors can come with top side, bottom side and both side connection contacts. Some require cutouts on the flex for proper griping and they usually have different specs for how deep the flex will go inside. This is important if the connector pattern on the flex has alternating teardrop shapes. The edge pads may have special patterns as well. You also want to match the lock mechanism, such as fliplock (enters where the lock mechanism is) or backlock (the lock mechanism is opposite the entry slot). Yours should be a backlock but the picture you show of potential replacements appear to be fliplocks.
So you need to look at the spec sheets and measure what you already have to find the best match. Order more than one because they are easy to damage during the soldering process.
Score 2
2 Comments:
I ordered 2 pcs of the last picture. But the problem is i can't find the specific spec sheet for my model laptop. But the defect part is so little.
by
No, you need to look at the spec sheets for the connectors and match it to what you physically have on hand. Use a magnifying glass to help out.
by
Add a comment
It says 1A 40. Which connector can someone recommend me?
Add a comment
Add your answer
Murat Metin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 517
