Repair for cars and trucks manufactured by German automaker Mercedes-Benz.
207 Questions View all
fuel actuator where is it located
1989 mercedes benz 230e when i start the car i tern the key it starts and when i let go of the key it stops checked the fuel pump relay and is ok wont to check the fuel actuator but carnt find it
Add a comment
Chosen Solution
Norm Guthrie, The fuel pressure regulator is mounted on the fuel rail of engine, Fuel Injection Electro Hydraulic Actuator Valve is #117 in picture below. There are also other causes for this situation, weak/faulty alternator, corroded/loose/damaged wiring,faulty ignition switch, crank position sensor failing, fuel pump relay, MAF sensor, etc.,etc.. Before changing parts(unless already diagnosed), if you can have the car scanned for trouble codes, as this may help locate the issue. Some of the auto parts suppliers offer free code reading like Pepboys, Nappa, Advanced auto parts,etc and some of the guys are very knowledgeable and may have seen the issue often and put you on the right track. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.pelicanparts.com/techarticles...
Score 3
Add a comment
Most Helpful Answer
Hi,
If you mean the fuel pump, it is located on the underside of the car, behind the rear rightside seat.
Here is a link which describes how to replace the fuel filter on a Mercedes Benz W124 vehicle. It shows the fuel pump as well, (see fig 2 ).
(The MB chassis class designation W124, 1984-1995/6, includes the 230e, scroll down to Models section)
Hopefully this is of some help.
Score 4
Add a comment
Add your answer
Norm Guthrie will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 8
All Time: 914
