Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
Problems with touch screen
Hello you guys,
i have some troubles with an iphone 6s screen, i wanted to know what i might did something wrong here,
i buyed a iphone 6s screen and i assembly all the parts together, i put my screen in to place and HURRAY it works, but after a few minutes when i was working on it , i start to notice there is a scroll problem and also when swiping its some times stuck. i reopend my iphone to make sure the connector was propperly clicked in,i try to use my cracked screen and there i did not have any problems, and when i place the new one in aggain its back from the start
can you damage a componment on the lcd screen when placing the heat shield on?
or is an faulty screen , because i dont have any pixel dots or any other problems with 3D touch etc,...
Thanks for replying!
Add a comment
1 Answer
Chosen Solution
You may have damaged the connectors or torn the flex cable so I would take a closer look to see if there is anything obvious. Otherwise, you probably have a defective replacement screen. Check with the supplier to see if there is any warranty on it.
Score 2
1 Comment:
Its the sceens that is faulty i guess, orderd other and it works.
by
Add a comment
Add your answer
glennjacobs will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 121
