Do not forget to check your monitor:
Symptom
Screen is blank, and monitor power light is not lit.
Possible solution
Reconnect the power plug on the back of the monitor and the wall outlet.
Press the On button on the front of the monitor.
Screen is blank. Press the space bar or move the mouse to make the screen display visible again.
Press the Sleep button (select models only), or press the Esc key on the keyboard to resume from sleep mode.
Press the On button to turn on the computer.
Inspect the monitor video connector for bent pins:
If any of the pins are bent, replace the monitor connector cable.
If no pins are bent, reconnect the monitor connector cable to the computer.
1 Comment
cluelesssaint you have double checked your monitor to make sure that it is working and properly connected?
by oldturkey03
