rear power window winder does not work
how do I fix a power window winder that does not work?
Thanks for your input Jimfixer.
The widow does not operate from the switch on the driver's door or the rear passenger door.
The window stays down and there is a noise coming from the motor and a clicking noise when I press the close window button. From the info in your email it sounds as though the regulator has gone.
What is a regulator and what is its function in the widow winding process?
Regards Vic
Victor There are a host of things that could cause this problem . The power motor , the regulator , the switch or the wiring . If the window works from one switch but not the other you can guess its the switch or wiring to the switch but if it doesnt work from either I would look to wiring or motor. If there is a hum coming from the motor then it would be the regulator . To find out for sure remove the door skin and test the wiring for power make sure there's power coming to the motor when the switch is activated . With a little more info I could better diagnose the problem . Is there any sound when you do try to use the window? Is the window down and wont come up ?Does it hum or click ?
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 38
