Repair guides and support information for RCA-brand tablets.
Why wont it charge
The voyager tablet that my son just got for his birthday won't charge
Add a comment
1 Answer
Most Helpful Answer
Linda Robakowski , You could try a factory rest as this some times can fix this type of issue(link below). If under warranty consider returning for replacement/refund/repair. The battery, cable/charger or charge port may be faulty damaged. Look in the charge port and blow/pick out(carefully) any dust/debri that may be causing an issue also look in the port for any bent pins and straighten very carefully with a tooth pick. Try a different compatible charger/cord to see if that is the issue. If different compatible charger/cord does not fix and port looks/test good, the battery or connection could be bad, if able to clean battery connections and reconnect/install battery, still not charging battery probably faulty. If port is found to be bad/loose/damaged , this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://unlockandreset.com/rca-tablets-al...
Score 3
Add a comment
Add your answer
Linda Robakowski will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 70
