Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
Problem after changing charging IC
Hello everybody,
The iphone 6 plus battery started to drain, I tried everything from changing the battery and chargers to changing the U1700 ic chip which actually worked!
But unfortunately I couldn't connect it to a computer nor plug it in a charger, it works temporarily then turns off with apple logo loopinf when plugged in, i tried changing the ic chip twice and the problem hasn't been solved, anyone has any solution for this frustrating problem?
Score 1
Add a comment
Its possible You damaged additional components when replacing the charging ic have you tested the Components next to the charging ic for damage?
Add a comment
i have iphone 6 plus charging not working i change u2 ic but not working
please help me
1 Comment:
i have iphone 6plus not charging i change u2 ic but still problem plss help me
by
Add a comment
Add your answer
Yousef will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 2,722
