Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
413 Questions View all
Old 3ds XL: Bottom Screen no picture, Hinge turn shuts it off.
My 3ds XL (old) is not working. The bottom screen is still interactable, but has no picture. Also, when I turn the hinge at an angle, the thing turns off.
Here's A Picture
Any help is appreciated.
Score 2
Add a comment
1 Answer
Most Helpful Answer
@ctrlaltdelete,Ren, Maybe there's a problem with the cable connection to the top screen that's causing it to power off as the hinge moves. Below 1st link is to disassembly guides to enable you to get inside device to check and clean all connections/reseat them and check for damage. Clean all the connections with a Qtip dampened with 90%+ Isopropyl Alcohol and reseat for good connection. If needed the 2nd link is a replacement lower LCD.
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Nintendo 3DS XL
Nintendo 3DS XL Lower LCD
Nintendo 3DS XL Lower LCD Image
Product
$24.99
Score 4
2 Comments:
Thank you. I still need a Phillips #00, so when I get that screwdriver I will try it out. Thanks again.
by
@ctrlaltdelete,Ren, thanks for replying back,Good luck with your 3DS XL repair.
by
Add a comment
Add your answer
Ren Bannon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 321
