Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Ear speaker, headphone jack and microphone is not working
Hello friends,
I have issue with iphone 6.
I have replace ear speaker and charger port flex.
Also have try soft reset and hard reset with iTunes.
All flex connected:
- Ear speaker is not working.
+ Front camera is working
+ Light sensor is working
- Headphone jack is not working
- Microphone is not working
+ Loudspeaker is working
+ Charge is working
+ Vibration is working
-Video have messy noice.
Ear speaker flex off - No voice on video - Headphone jack and microphone is not working.
Now I'm waiting new ear speaker flex. Should I try change back camera microphone?
Could it be logic board issue?
How I can confirm it's not software issue?
2 Comments:
@albertfigure What was the reason of changing the ear speaker and charge cable?
usually this get clogged with dust or lint and a simple cleaning does the job.
did you make sure everything get back int the original position?
the mic did record something or just random noise or nothing at all?
by
Reason was this problem, but no any change after changing those parts.
Yes, all screws (correct size), connectors etc.
Random noise on video when ear speaker is connected. After I plug off flex of ear speaker no any voice on video.
When try call only loudspeaker is working normally. Mic - no voice. Headphones - no voice. Ear speaker - no voice.
by
Add a comment
There are two issue as I can find about the device.
Lets solved the first one Ear piece not working. When you change earpiece and front camera flex there are 4 golden dots which needs to get connected to the flex. Please align everything and lock the silver plate with proper screw. It should be fixed
Second, Headphone Jack one of the pin in the headphone might have been damage or stuck. Try inserting headpone or change the charging flex.
1 Comment:
I have changed the charging port flex twice - No progress with the problem.
I know it is tricky to get to ear speaker/front cam flex and parts into place. I have done it several times before. I'm still waiting new ear speaker flex from China. I hope that it will arrive this week and problems will be solved soon.
by
Add a comment
I changed ear speaker flex - No any effect.
Is there any diagnostic tool for logic board?
Add a comment
Add your answer
Albert Figure will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 832
