Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
After a screen replacement a strange issue happened.
Hello All,
I recently purchased a used iPhone 6 from a friend (who got it new). The iPhone's screen was destroyed, but in working condition (it was an OEM screen, I.E. it was the factory screen). I bought a replacement screen from a seller on Ebay. I replaced the screen, the good part of it was the speaker phone started working, but the bad was that the proximity sensor stopped working, which was no big deal for me. The screen worked fine for about 6 months, but today the cheap glue split the glass from the LCD. Once it split the internal parts such as the proximity sensor and the camera bracket came out. I opened the phone (after I shut it down) and took out the screws, then preceded to disconnect the flex cables. I put the internal parts back in place and they went in fine. I re-connected the flex cables and turned on the phone to check the LCD and digitizer to be sure it worked. The phone started up, but the screen only showed some backlighting, but no picture. The screen worked before I did this, but now that happened. Also when the phone fully turned on I got the notification sound (it was from Facebook). I turned the phone off and the proceed to check for the 'long screw' problem. The bottoms of the holes didn't appear to be scratched/depressed. I also did not put any of those screws back in after I took the screen apart, so it shouldn't be that. I ordered a new screen to replace it with. Any suggestions to help? Should I remove the battery connector for a few minutes and try again?
Thanks for any help you provide!
Thanks,
-John
Add a comment
1 Answer
Chosen Solution
Did you make sure to have the battery unplugged prior to reseating the screen cables?
For proximity sensor did you buy a screen with it already installed? For that problem to be solved a new front camera flex assembly needs to be used.
For the black screen lit up and working sounds like a damaged LCD cable resulting in a replacement screen required.
Try doing a quick reset using home and power button for 10 seconds and see if it turns on with display after holding power button.
Score 4
4 Comments:
Hey Ben,
I did not unplug the battery before reseating the screen cables, but I didn't do it the first time and if worked fine. Could I have blown a capacitor? Also, the new screen I bought will come with a proximity sensor pre seated. Before I plug the screen back in should I disconnect the battery? Should I add the little components back when reseating the connectors? Lastly, I have ios10 so will the quick reset work?
by
Make sure to have the battery always unplugged when plugging and unplugging screen cables.
by
Alright, thanks for the help!
by
I replaced the screen, and it is working flawlessly! Thanks again for the help!
by
Add a comment
Add your answer
John Doe will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 96
