sunroof is leaking into my interior lights between the visors
2001 Subaru Outback the sunroof is causing water to run into my interior lights between my visors
Hi,
It may be that one or both of the front drains on the sunroof is blocked or has become detached from the sunroof.
Here is a link - go to post #27 which shows where one front drain outlet appears in a 00-04 Outback. There should be another one in a similar spot behind the front wheel on the other side.
Be sure to check the sealing inside of the sunroof, for my car the sealing is solid, so no leakage should occur.
Thanks,
-John
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 1,591
