Released in 2013 Model number: ONETOUCH 7024W FCC ID: RAD386
Why isn't my touch screen working at all? I even hard reset it 10 time
Why isn't my touch screen working at all? I even hard reset it 10 times .. Now it starts up like a brand new device, but the touchscreen is nonresponsive .. Can someone please help me out. Alcatel one touch fierce 5054n
1 Comment
It sounds like the digitizer might be bad. From the teardown guide on the device page I suspect the digitizer may be in the LCD display. There is no guide for it as yet but the teardown might help.
Alcatel One Touch Fierce Teardown
by
Add a comment
1 Answer
Chosen Solution
There are 3 possibilities
a) Digitizer went bad. -- you would replace the digitizer to fix this. Follow the iFixit tear down guide to replace the digitizer. Normally its easier to replace the LCD + Digitizer at the same time.
b) Digitizer cable is loose. -- Follow the iFixit tear down guide to open up the phone and check the cable.
c) Logic board is bad. -- Follow the iFixit tear down guide to open the phone up to change the logic board. However, if it comes down to this, you should look to get a new phone.
Score 1
Add a comment
Add your answer
Westlee will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 951
