Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Front camera and speaker is short on the motherboard.
Hi,
I have an iphone 6. The LCD doesn't power on when all the flex cables are connected (LCD, digitizer, front camera/speaker assembly, finger print scanner). When I connect the three flex cables (LCD, digitizer, finger print scanner) the LCD powers up. So I came to a conclusion that the front camera/speaker is short on the logicboard of the phone. How can this be fixed? Any help will be appreciated.
Thanks
Add a comment
1 Answer
Chosen Solution
Follow this guide and replace this part.
iPhone 6 Front Camera and Sensor Cable Image
Product
$19.99
Score 1
2 Comments:
Flex cable is not the issue as I was able to install the LCD assembly with front camera and speaker on another phone and everything worked.
by
Have you tried the other flex cable from the other phone? If the fault continues to stay with your phone, check the connectors for broken pins or pried components surrounding it.
by
Add a comment
Add your answer
Jun will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 54
