Power comes on then goes off
I have a Sanyo ce26ld81-8 hd tv the power won't stay on put in new fuse but light comes on then goes off again so have no power how can we repair it please thank you.
Score
0
Hi,
Which fuse are you talking about? The house power fuse or the fuse on the power board inside the TV?
Either one, does the fuse blow every time after you turn the TV on?
Is the TV connected to the wall outlet via a powerboard at all? If so try connecting it direct to the wall outlet and see what happens.
With the power disconnected from the TV, remove the back off the TV and see if there is any evidence of a problem on the power board in the TV e.g. burnt components or blown capacitors etc.. The power board is usually the one where the power cable connects to.
If in doubt take some close up pictures and post back here and hopefully someone will be able to help you.
Adding images to an existing question
by jayeff
