Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1526 Questions View all
Why isn't my touch screen not working?
My touch screen hasn't been working since my iPhone split. The screen lifts up while attached still but I can lift it.. Now, when Its split like this.. It isn't showing the battery. Its split from the touch screen I think. Is this something you guys can fix?
Update (03/19/2017)
Here is a picture of my phone.
Add a comment
Chosen Solution
if the touch function is not working you probable disconnected the cable inside when you split the phone. take the phone apart and reseat the digitizer and screen connectors then use a two sided tape to close the phone so it doesn't open accidentally again . This guide should help
iPhone 6 Plus Screen Replacement
Score 3
1 Comment:
Thank you. I will try and do this..
My home bottom us detached from the cable, will I have to buy a new home bottom?
by
Add a comment
What do you mean it split? Did the glass separate from the frame?
Score 2
4 Comments:
Yes I provided a picture. Not sure how to explain it.
by
It just needs a new screen, that is a side affect of a bad quality aftermarket screen.
by
How much are the screens approx?
by
Depends on where you get it, they can be as cheap as $20 on eBay.
by
Add a comment
Hi,
With it seperating from the frame, this would've more than likely damaged the cables, this is because it is a cheap screen replacement.
Also, because your home button is attached to the glass, it has been torn, and therefore won't function, so would need replacing, but replacing it won't have Touch ID. :-)
Score 1
Add a comment
You need a new screen :(
Add a comment
Add your answer
Brittney will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 161
