broken antenna/gps noticed on replacing rear case
when replacing rear case, you state that some of the cases do not have screw hole available where the antenna/gps piece is at top of case. In addition, narrow piece of plastic having points on the end is broken. Do you make replacement antenna/gps? WHat does this pointy part do? If there is no screw hole how can it be repaired? Thanks
