What type of bolt is this? how can I remove it? any homemade way?
Thanks!
Thanks!
@xterno50 ,Roberto , 5 node security head/Security (Temper-Proof) Torx Plus. Depending on the size and how tight it is, you could try a #1,2,3 square(Robertson) screw driver or purhaps tight fitting slot screw driver as seen in video below. If not coming easily stop before stripping and perhaps borrow or purchase the correct bit or driver. Video below may help. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
thanks for taking your time to reply, but it is not the same screw. The one you mentioned is hollow in the middle. Maybe in the picture it seems hollow, but it is flat in the middle.
Roberto, are you talking about the 5 star type screw, it looks like some one has perhaps drilled it, trying to remove the head, not positive but looks strange. Check the link below.
This is the set you wil need to buy to get that out https://www.newelectronx.com/e-newslette...
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 4
All Time: 2,009
