Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
220 Questions View all
Screen turns on. But turns off later.
my iPad when I turned it on. Everything worked normally but maybe 20 seconds to 1 minute later it crashes and makes a flash before the display turns off. But the backlight is still on. I have restored, reinstalled ios 10.2.1 and put it in rice. Yet nothing works. https://youtu.be/Rwh-1ojZuRI here is a video of what actually happens
Add a comment
1 Answer
Chosen Solution
Why did you put it in rice?
If your iPad was in contact with water, then you need to have it cleaned asap before it dies completely. You could try this yourself seeing as how the shields do not have to be de-soldered.
  • Open your iPad and remove the logic board (follow this guide)
  • Inspect the logic board, especially around the connectors and look for corrosion.
  • Put your board in a container with >90% isopropyl alcohol and let it sit for a while.
  • Use a soft brush, like a toothbrush and lightly brush away any corrosion you see.
  • Rinse in alcohol and repeat.
  • Let it air dry for a day.
  • Re-assemble and hope for the best.
A professional repair shop that does water damage repair may be able to recover your device or the data because they have access to pro-level ultrasonic baths and specialized cleaners as well as the skills to troubleshoot your board.
Score 1
Add a comment
Add your answer
Taylor Ness will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 74
