Not shutting 0ff ewhen cycle is completed
Code c with reverse C shows in time box at end of cycle and dryer does not shut off
amana dryer NED2700TW
pgbock the C with an invert C does not show up in the manual at all. There are a few reasons while your dryer may not shut of
Will Not Shut Off
• Short in Sensor Circuit.
• Check Membrane Pad.
• Check Electronic Control Board.
Troubleshooting the electronic control circuit:
• Check for miswiring of the electrical connector at the electronic control board.
For the reason Try to run the diagnostic test and see if it gives you a valid code. Use this document NED7200TW techsheet to see how to run the tests and what they mean
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 60
1 Comment
pgbock is it a NED2700TW or a NED7200TW
by oldturkey03
