iPhone 6 water damage dead
Hello to all !!
My iphone is dropped into fresh water and now no longer lights.
I removed all the shield of the motherboard and made cleaning with isopropyl alcohol.
Looking under the microscope, I found this component oxide (resistance) L1503 which is part of the VCC MAIN.
Could this be the problem?
Before removing it I would be sure
thank you
Update (03/20/2017)
MINHO hello, thanks for the quick response .perhaps now everything is clear, I believe the 80% that the short circuit is located in backlight line. I noticed that the tooth of the LCD connector and the filter (exactly the first on the right, connected to the FL2024 filter are burned). After the diode D1501 seems broken, also it burned this .Spero think that's why it does not turn and is not detected by iTunes My iPhone
4 Comments
Could this be the problem, Che does not turn on the backlight ???
thanks
by man_fry
I measured with test 200 kilohom, is that the capacitor C1505 -C1530 -C1531 and give me 0.00 (so I think in the short-circuit line Backlight)
Could this be the problem, Che does not turn on the backlight????
To switch it on what should I do?
by man_fry
You should comment on the answer, it is easier to follow...see below.
by Minho
I lifted the D1501, but still is the Short Circuit ..
I misurate the voltage of C1552-C1597 capacitors and 3.7 Volts, then exclude both the Coil L1503.
Right?[image|1055536]
by man_fry
