Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
strange colors on iPhone 4
Hi!
When I replaced the iPhone 4 LCD + touch, I have strange colors, not normal, where can be problem?! I dont thinks so that is in LCD cause when I return my broken LCD + touch also same problem, the problem has appeared when I replace LCD + touch.
Have you ever had similar experience?
http://img826.imageshack.us/i/img00321p....
best regards, marko
Score -1
Add a comment
Chosen Solution
Pongra try this. Go to settings and then general then accessibility and then turn off the white on black option. I seem to remember having read something about the screen being in negative mode....reversed colors. Not a guarantee, just a start. I know it is somewhere in the settings. Let us know.
Score 5
4 Comments:
and of course make sure that all cables and connectors are properly seated and secured.
by
Yes, thanks for that, I did it and everything is good now, thx again guys.
by
Dear oldturkey03,
Thank you so much!! That worked for me too!!
Bless you!
by
Thanks oldturkey03! Worked like a charm.
by
Add a comment
I have just replaced my old screen with a DIY kit and it seems to be in negative and when I put the actual iPhone in negative it goes kinda normal again but it also has lines going across the top of the screen, HELP!
Add a comment
Add your answer
pongra will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 10,032
