Washer buttons won't stay on
When I press the power button, all lights power on then right back off. I replaced the dispenser PCB assembly, but that did not change anything.
First unplug it for five minutes to allow it to reset.
That failing take a look at my answer here:
@kodiakbear ,laurinda59 , unplug the washer for 5 minutes, then plug it back in and listen for a click. If no click possible bad CCU, also could be door lock switch faulty or bad connection, start switch and or timer faulty, washer motor faulty, main control board faulty or shorted. Check the links below for more trouble shooting info. the last link is the service manual that could help big time in diagnosing your issue. Good luck.
https://www.youtube.com/watch?v=YdWuLw15...
http://removeandreplace.com/2015/04/10/w...
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 5,757
1 Comment
Washer won't stay on. Lights do come on but turns off or just flashes. What could this be???
by bm97057
