Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
No service after cleaning
Hi Guys.
OK i have some iPhone 6 with all have the same issue they came in with no sim issues which i resolved by cleaning the sim port but a new issue has arose.
The phones either keep saying searching or no service but if i clean the connector the antenna connects to the little push on in between the battery & dock connectors on the board i get a signal with 4G.
I try different sims in them & they work great until i reset them back to factory settings they then go back to searching or no service.
Would it be worth warming the connecter up on the board essentially reflowing it?
Anyone else have this issue & did you resolve it if you did how please?
Any help or suggestions would be amazing.
Thanks guys in advance
3 Comments:
What do you get when dialing *#06#
Do you see the IMEI or not
by
I have not tried that yet didn't think it would be baseband issues as i do get a good 4g signal if i clean the connector. I did try heating the connector up 2 of them worked for about 10 mins the other just over 24 hours but all 3 have gone back to no service. i'll post back once i have tried checking the imei.
by
Update yes all 3 are outputting an imei no while it has no service.
by
Add a comment
1 Answer
Afther a factory reset did you connect it with Wi-Fi and adjust time to the correct location?
3 Comments:
Yes i have factory reset all 3 devices & i still get no service issue.
by
afther a factory reset you have to connect to a wifi spot or ajust correct time and location otherwise it keep searching or display No service in the left upper conner!
by
Is the device bent at all near the sim tray? Sounds like your having some hardware issues.
by
Add a comment
Add your answer
Kenny Leonard will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 2
All Time: 246
