Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
487 Questions View all
Homebutton broken, Finger id working after replacement?
Hey guys,
the home button of my galaxy S6 won't work properly. It does recognize my finger id and unlock the phone, but nothing happens when i press the button.
My question is: Is the finger id sensor going to work normally if i would replace the home button?
I know from iphones, that the finger id is blockt with other buttons then the originally installed. Is this so with the galaxy S6?
Add a comment
1 Answer
Chosen Solution
Hi Lukas
For Samsung S6 the actual physical button is on the charging port. So all you need to do is replace the charging port and your id should work fine.
Good luck
Score 3
1 Comment:
Cool. I already thought that i had to decide between finger print or homebutton function.
Thank you for your quick response =)
by
Add a comment
Add your answer
Lukas will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 5
All Time: 222
