Up to 20% off select tools
Asus ZenFone 2 (ZE551ML) is an Android smartphone manufactured by ASUS released March 2015.
How replace power button
please help how i can repair button phone dont turn on
2 Comments
I need help to find where to get a new power bottom for Asus Zenfone 2
by Share
You can get it on Aliexpress.
by Share
Add a comment
Most Helpful Answer
@raw771 , Anton, Make sure battery is charged, try a different compatible charger if need be. Use the guide below to disassemble the device so you can disconnect the battery for 5 minutes,then plug back in and check/reseat all the connections to make sure all are connected well. Try and power on phone. Good luck.
Asus ZenFone 2 Motherboard Replacement
Score 2
Add a comment
Unless you have a micro soldering setup, you must either send it in for repair, get a new motherboard, or a new phone. You can, however, keep using your phone as is, just don't ever let the battery die.
Score -1
1 Comment:
Then whats the point of having a MOBILE phone? its anchored to the wall by a charger as (some) home phones are anchored to the wall by a jack.
by Share
Add a comment
Add your answer
Anton will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 4,271
