This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
mine won't stay on past lifting the lid halfway - just shuts off.
1. toggle side switch
2. begin raising lid
3. device starts and game is accessible and playable until lid reaches halfway point
4. at halfway point (approx 90 degree angle to base), devices shuts off
Using toggle side switch produces a quick flash in the lower screen.
Add a comment
1 Answer
Chosen Solution
@thepogan , Kayla , It could be a bad connection on one of the display's ribbon cables or a bad cable (probably the upper cable connection or cable damaged). Below are links to guides that show how to partially disassemble the DS so you can check the cables for damage and reseat them to make good connection if not damaged. Good luck.
Nintendo DS Lite Upper LCD Replacement
Nintendo DS Lite Lower LCD Replacement
Nintendo DS Lite Lower LCD Image
Guide
Difficulty:
Moderate
30 minutes - 1 hour
Nintendo DS Lite Upper LCD Image
Guide
Difficulty:
Difficult
2 - 3 hours
Score 2
3 Comments:
L Pfaff, I've uploaded an image. Please confirm this cable is broken. Sorry it's taken so long to get back to you. https://imagebin.ca/v/3NooMlfyzkSh
by
Kayla, The pic. was pretty blurry but cable does look damaged and is probably the issue.
by
L Pfaff, Thanks.
by
Add a comment
Add your answer
Kayla will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 90
