Headlights blinking bright to dim
Headligets blinking bright to dim
christinezaf if the brightness of your headlights pulsates from bright to dim and back to bright have your alternator, battery and wiring checked. Sometimes bad brushes as well as corroded wiring can be the cause of that.
Going to try changing negative battery terminal connector it is corroded will let you know if that fixes headlight malfunction
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 61
