Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Screen believes I'm touching it
The screen believes I'm sending it inputs eg thinks I'm pressing the screen. It seems to not do it as much when the screen's darkness is lower. I have tried to reset it but it does not fix it. Any suggestions on how to fix this
Thanks for any responses.
Add a comment
Chosen Solution
@hshark93 , Harry, Have you tried factory reset, if not you may want to try that and if that does not solve the issue the Ghost touches could be from a bad/faulty digitizer on the phone. I will post links to replacing the digitizer below and a link to just the glass digitizer. If you would like to make things quite a bit simpler there is also a link to the screen assy. which cost more naturally but saves some headaches. Before changing you may want to open the device and check all components for loose/damage/corrosion and reseat all connectors to be sure they are connecting well and try phone. Good luck.
https://www.youtube.com/watch?v=z9drzO9h...
http://www.ebay.com/sch/Cell-Phone-Scree...
iPhone 6 Screen
iPhone 6 Screen Image
Product
iPhone 6 Screen
$44.99
Score 1
Add a comment
has it been dropped or any thing like that or is the screen cracked ? if it has it might of damaged the screen of the logic board.
please put comments if you have any questions.
3 Comments:
There are no cracks on the screen and it did not occur after a drop, it started by itself, randomly.
by
ok do you have the phone taken apart yet?
by
if you do, do what l Pfaff said that was the same thing i was going to tell you.
by
Add a comment
Add your answer
Harry Brackley will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 52
