The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3541 Questions View all
bootloop can't go into recovery
HELP my iphone is now in a endless bootloop. I can't turn off iphone also can't get it into recovery. How can i get the phone off?
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
Eventually the phone will turn off when the battery is depleted...but that's probably not what you want to hear ;>).
You don't really explain what happened to your phone before this issue. Was it dropped or did it come in contact with water? Are you using genuine Apple chargers and Lightning cables? How was the battery performing prior to this; was it already weak?
You could just have a dead or dying battery, that will cause bootlooping. Change the battery and see if that solves your problem. Otherwise, you could have a problem with the charge circuit (U2/Tristar). These can be damaged by serious or repeated drops, water and cheap chargers.
If the problem has nothing to do with the battery or charge you could download 3uTools and it will allow you to exit recovery mode.
Score 2
Comments:
the problem is that i can't get into recovery mode any more. only looping and not recognized by computer, the problem occurred when it failed to restore itunes error 9 it's only 10 percent loaded with an os at that point. this phone i bought second hand and is checked by me icloud free. so i do not know much about the state of the phone. it looks good and not opened yet at outside. that's why i want to wait till last option to open up the iphone and check and replace battery too to see if that's the problem. it's now at BLOD really without chances to get it recognized by computer and without be able to get it to recovery mode. maybe my home button or power button died at this night. and i know about how to force restart and how to get into DFU. i know also that i should charge the phone while in recovery mode, but for now the battery is really empty.
by
Like I said...change the battery first.
by
Add a comment
Add your answer
Michel will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 19
All Time: 101
