Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Bottom half of screen doesn't respond correctly
I have an iPhone 5s that doesn't respond correctly on the bottom half of the screen. It works but when using the keyboard the input is wrong, for instance if I touch F, I might get G or G and F. It is not the digitiser, the screen has been replaced with one that was working perfectly on another 5s so it is something within the phone itself, any ideas?
Add a comment
1 Answer
Chosen Solution
A few things to consider here:
  • The logical thing to suspect is the screen. If you are confident it is good (can you put it back on the original device it came from to confirm?), then move on to the next item
  • There may be a partial connection only so check the digitizer connector. Also, it should have a little black foam on top of the metal plate on the flex (look at this picture). That allows it to stay firmly connected under the bracket. Don't underestimate the importance of this.
  • You could have a problem on the logic board with the Touch IC. If the phone was bent in the past or dropped often over it's lifetime, this is a possibility. This would require a micro-soldering repair.
Score 2
1 Comment:
I definitely sure it's not the screen. The screen that came with it was the exact same way. So it's going to be one of the other 2. I'll open it up tomorrow and see if I can see what the problem is. Thanks.
by
Add a comment
Add your answer
Mary Ellen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 78
