Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
Question Closed
Damaged MobileSubstrate.dylib needs Irecovery and IBSS+Iboot Payload
I renamed the /Library/MobileSubstrate/MobileSubstrate.dylib as I planned to upload a working copy of the original file (Original was corrupt). While uploading it froze. I now can't boot to SSH. Only Recoverymode and DFU. I need to use the IBSS+iBoot Payload exploit to create the 2 RamDisks to SSh into the phone on port 22 using RamDisk prep too, iRecovery and Iphone_Tunnel. The description of how to create the bin file and use Arm-Elf to complile it are very scratchy. Any help on this please. I have ARM-ELF and Cygwin and also a GUI of iRecovery. Please see this link for my problem. http://forums.openpwn.org/viewtopic.php?...
Add a comment
1 Answer
Most Helpful Answer
Hello,
Long time it happened to me. I could not boot using the information on the link pointed by you at the time I had the same problem...
My solution, as I am running Windows, I have installed MAC OS X on Virtual Machine then downloaded "Redsn0w" (I guess it was redsn0w). Then changed the application to payload MobileSustrate.dylib together with Cydia and jailbreak. It worked fine for me...
Sorry to not share the same custom version but it was gone in my last PC...
I hope it helps
Score 2
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,693
