How do you change the power button to snooze?
When my alarm goes off, I press the power button but all that happens is the vibration turns off. Is there a way to set it up so I can use a button to snooze my phone? I'm not a big fan of having to pull out my phone, unlock it, and electronically snooze it. Thanks!
1 Comment
Charlize Rover , found no info.on setting up a snooze button for the Blu, but perhaps you could install a alarm clock App with snooze, some apps can be shut off by voice,touch,button,etc..Hope this may help you.
by
Add a comment
1 Answer
Chosen Solution
Hi @strawberryabc0,
Not sure if settings are the same but try the following:
Go to Home > Clock > tap Settings icon (either 3 vertical dots somewhere on screen or if none then the right hand soft key below the screen, select Settings if more options are shown), scroll down to find Volume Buttons tap to enter select Snooze. Then scroll to find Snooze Length , tap to enter and select desired length of time then OK
Score 2
Add a comment
Add your answer
Charlize Rover will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 2,147
