What is output to separate monitor
How do I transfer image to separate monitor
@rbarney, Rick, Depending what your laptop has for video out connections will determine how a external display can be hooked up as there is more then one method usually. HDMI, VGA, DVI,Mini-DVI, Micro-DVIVGA, S Video are some of the common cables/connectors/adapters used to hook up an external display. Links below give some detail on hooking up external display and the different connections. Good luck.
http://www3.lenovo.com/gb/en/faqs/laptop...
https://www.youtube.com/watch?v=89dof7m2...
https://www.youtube.com/watch?v=DCrffkpk...
You would need a second monitor to hook it up to and possible an adapter. What is your laptop model so i can determine if you need an adapter or not and if you need an adapter i can find you an adapter that would allow you to connect it to another monitor.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 26
