Repair guides for Dell Inspiron laptops. A line of mid-level Dell laptop computers.
1402 Questions View all
My laptop won turn on its stuck on start up screen then goes black
Hi I need SOMe help with my dell Inspiron laptop, whenever I turn it on it shows me a black screen which says disk cleaning c or something like that and it gives me like 10 seconds so I can decline the disk cleaning but when I decline it goes to the blue screen and says welcome but after 2 minutes the screen turns black and I can move the mouse some one please help me cause this is my dad's laptop and he is pist at me for making it wrong but the problem is I didn't do anything to it it just started acting up by itself it also doesn't work on safe mode and when I do the disk checking it won't work I've let it on for about a day and it is still at 10% some one pleaseeeeeee hellllllppppppp meeeee.<3
6 Comments
Hi,
What OS is installed and what is the model number of the laptop?
by
I will have to look I don't have my laptop on me ATM I'll tell you tomorrow
by
It's window 7 dell Inspiron n5110 and don't know what year it was made in.
by
Hi,
Have you got the installation disc?
If so boot from it (change the boot order in BIOS to cd drive first, and then select the repair option NOT the install option.
Here is a link that explains what to do.
http://www.techsupportalert.com/content/...
by
Have no idea how to do that :(
by
Show 1 more comment
Add a comment
1 Answer
Chosen Solution
Do you have another PC that you can connect the SATA HDD to? I think that some malware may have gotten on there. Tell your dad that malware is a virus that bad people put into the internet to try to infect and control someone else's PC with. It's not your fault. And don't use the P-word here.
What Dr. amanat9748 needs is:
1. Windows Desktop PC
2. Open SATA slot inside your PC or USB to SATA adapter.
3. Glary utilities installed.
4. Malwarebytes installed.
Instructions:
Step 1. Install Glary utilities on the desktop. Then, install Malwarebytes. Just Google the names and find the correct websites. Follow the install instructions from there.
Step 2. Find out how to remove the old HDD or SSD from your laptop. Once done, if you have an extra internal SATA slot, power down the PC, find a SATA power cable coming from the power supply and connect that to drive. Then, connect a SATA cable (unplug from DVD drive if necessary, same for the SATA power) to the drive. Then turn on the PC. If you have a SATA to USB adapter, just plug the drive into the adapter then plug the adapter into the PC.
Step 3. As soon as you finish step 2, run Malwarebytes, Windows defender (built into Windows), and glarysoft malware hunter. It should detect any malware on the drive.
This is a good protocol for malware on a drive. Although your drive probably does have malware, it may not be the problem. This can't hurt though, and it's good protection. If it can't find anything, use Glary utilities to do a disk fix/clean up/whatever you think will help.
Hope this helps!
BTW, what model is you laptop?
Edit 3/8/2017
Step 4: open device manager and right click on the drive from your laptop (will be called recovery, system drive or something like that), and do the following:
I have now made a guide to better illustrate this
How to remove malware from an infected windows PC
Score 1
Add a comment
Add your answer
amanat9748 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 251
