Repair guides and support for the Galaxy E7, an Android smartphone released by Samsung in early 2015. Features a 5.5" Super AMOLED 720 x 1280 display, a quad-core 1.2 GHz Snapdragon 410 CPU, and 2 GB of RAM.
How to change the screen
How do I change the screen?
Add a comment
1 Answer
Here's a video on how to replace the screen.
https://www.youtube.com/watch?v=MRzhLEMx...
Seems simple enough, although you'll need a heat gun or an iOpenderor something similar.
Note: The %##&%&# in the video seems to destroy a perfectly good screen to replace a small crack in the glass.
Let me know if this fixes your issue.
Loosen adhesive or reflow solder with this 1500W heat gun. Low setting reaches 570 degrees F (300 degrees C). High setting reaches 1112 degrees F (600 degrees C). Image
Product
Heat Gun
$29.99
No more adhesive battles! With our iOpener, you can quickly and easily remove glued components in electronic devices whether you're a repair professional or beginner. Apply gentle, even heat to loosen the adhesive holding smartphone, tablet, and laptop case components and batteries. Image
Product
iOpener
$24.95
Add a comment
Add your answer
wafag1995 will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 18
All Time: 784
