Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
Replacement battery is causing apple hardware test error
I purchased one of your replacement batteries in part because my old battery no longer holds a charge and because the Apple hardware test stops at a battery warning.
I'm not sure if the full test is being performed. The replacement battery I purchased from you is also causing the Apple hardware test to have an error code 4xxx/4/4000005: "Battery"
I'm unsure if the full hardware test fully completed or not since something else is wrong with my computer.
Score 1
Add a comment
1 Answer
Most Helpful Answer
If the battery is not OEM, then it will error out
Score 2
1 Comment:
That might be it. Download coconut battery. It's free
by
Add a comment
Add your answer
Joseph Fusco will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 1,936
