f02 is cleared but the washer is not starting?
washer had an f02 code, so i cleaned out the drain put it back together plugged it back in and the controls lock/unlock stays lit. whats the issue.
@captainseanw .SEAN, You did not state your exact washer model #, so try this sort of generic reset procedure.
Press any of the buttons on the control panel to see if the buttons are operational, or check to see if the (control locked) indicator light is on. If the control panel is operational, you may have mistakenly locked the door.
Press and hold the (end of cycle signal) button for approximately three seconds until the (control locked) indicator light shuts off. This unlocks the control panel so that the washer is ready for use.
Lock the washer again, if desired, once you've began a washing cycle by pressing and holding the (end of cycle signal) button until the (control locked) indicator light turns on. Good luck.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 61
1 Comment
@captainseanw what model is your washer?
by oldturkey03
