Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Questions View all
No Screen Backlight (black screen) , video is OK
Hello !
my precious laptop, has the "black screen" problem,
external monitor is working properly,
I'm leaving in Greece and unfortunately after the economical crisis its not easy to give
the macbook for repair to the authorized service shop... there also so many
complaints for theie service (they are not an official Apple Store but a Reseller )
All started with the a broken left Option key... (which was stuck all the time)
I has to finish my job so I did the "clever" thought to "deactivate" the key by
cutting the metal connection under the key.
Result => Left Option + Control are dead ==> Power up with Power button
is now history.
I was trying to have the macbook always charged and in sleep mode,
and 4-5 times that was out of battery i did the trick with the power-on pads.
After the last power up with the power-on pads the screen is always black
the video is working good but No backlight.
I tried the NVRAM reset without any change.
SMC reset is not possible since I'm still waiting the keyboard from UK.
I found from this forum that my macbook has the 820-3115-B board.
I found the schematics and after studying hard this forum. i tried to locate the
problem of the board.
I'm a software guy (soft enough to get cuts from printer papers..) so its no easy
to follow the hardware jargon...
Anyway I have the following measurements:
The backlight fuse F9700 looks OK about 12V for each pin.
PPVOUT_SW__LCDBKLT_FB has almost 0V !!
The pins of LVDS connector I think are clean enough...
I send a picture of the area, Y9701 (LP8550) looks a little strange i think
(the color turns to black)
I had many problems with overheating of the bottom side ..
(the CPU was running high always due to some demanding processing)
and I can see many metal areas with red and dark color,
last year I'm using Macs Fan Control and the temperature is a little better..
I will try to find a service shop to replace the LP8550 ...
My question is the following :
If for some reason the WLED replacement goes bad .. is it possible to loose the whole
board ?
I mean I can work now with an external monitor , is it possible any failure to turn dead
the whole laptop ?
Update (03/06/2017)
The photo is not so clear ... sorry ...
1 Comment:
Thanks in advance for your valuable time !!!
by
Add a comment
You may have shorted something. Were you wearing an ESD bracelet? It is also possible that the LCD has a problem. Try reseating the LCD Cable. If not, you might need to try a new LCD. Did it have any water damage? Have you dropped it? I am familiar with this type of troubleshooting, but all of this info is a lot to take in. Hope that helped!
Edit: after looking at this a little more, the LCD backlight may not be getting any power. I'm not sure how to fix this, but I'm sure that it can be fixed.
Add a comment
Does the fuse have continuity? Check for that, then in the schematics test for the main voltage lines like PP_3V42_G3H, PPBUS_G3H, etc. Should test any voltage going into the led driver.
Add a comment
No bracelet during power on pads ...
I put out the LCD cable , no visible problem at connector pins , and reseat it without luck..
No water damage and No drop ..
I was really careful with this laptop , since I'm not planning to change at the next 10-15 years .. :)
I added a SSD disk, 16 GB memory , replaced the DVD Rom with 1TB hard disk ..
It was a hard working laptop and I was almost grateful as it was really reliable even after so much overuse
Add a comment
Yes the fuse is OK ..
Could you please specify what voltage to expect at the mentioned lines ?
Sorry but not familiar at all with electronics in action ..
My studies was based on paper , pencil and computer software some years later...
I will measure the lines tomorrow morning first think at work where there is a multimeter ...
Add a comment
Add your answer
Giorgos T. will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 265
