What is the nipple on the bottom of the carburetor for.
There is a nipple on the bottom of the Carburetor and i dont know what its for. There is also a hose that came loose, and i think it came from the carburetor. when i attach the hose, i dont know if the other end of it is supposed to go somewhere or not. when i turn the gas valve on, the hose leaks gas, so im guessing its supposed to go some where. i can provided pictures if they will help.
Score 3
1 Comment
Viktor Fruehauf give us the engine size and number or even better the number for the carb. If you do not have that give us more info on the 3-wheeler. Yes images will help. Use this guide Adding images to an existing question to post them with your question.
by
Add a comment
Chosen Solution
Viktor Fruehauf, Probably a vent #16 and overflow hose#12 . If either are dumping gas when you turn the fuel on, your float is stuck and it is flooding the carburetor and possibly engine. If oil smells like fuel do not run the engine until you get the carburetor fixed and the oil changed. ATV forum and carb. cleaning vid. links below and a link to new carbs. may be cheaper to buy new instead of rebuilding. Good luck.
http://www.hondaatvforums.net/forums/rep...
https://www.youtube.com/watch?v=Tw7zrVg9...
http://www.ebay.com/bhp/atc-200-carb
Score 5
1 Comment:
Should there be a hose attached to the nipple on the bottom of my carburetor, there is gas leaking out of it onto my engine
by
Add a comment
I am having exactly the same problem with my two Yamaha ATV 200E’s.
Fuel is dripping out of the hoses.
Could this mean I need to overhaul both carburettors?
As L Pfaff said, it could be part #16, which looks like an O ring.
Does the throttle valve, that screws into the top of the carburettor, continue all the way down to block off the nipple at the bottom of the carburettor (where the hose attaches to, that is leaking)?
Garry
Add a comment
Some carbs do not have a drain screw.
They have a hose attached to bottom of carb.
This has a seal in the end to stop FUEL coming out.
It is only used for carb servicing/draining.
Overflow on these carbs is higher up.
Took me ages to work this out.
Most advice is to do with float seal.
Mopeds tend to have the carb set I have described.
Especially chinese 4 strokes.
GOOD luck.
Add a comment
The seal on the carb prob needs to be replaced or if you don’t have money cut one out of a card board coke box. It worked on mine.
Add a comment
Add your answer
Viktor Fruehauf will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 44
Past 30 Days: 224
All Time: 30,245
